Monitors temperature, humidity, and atmospheric pressure in real time.
No Wiring Required | Temperature and Humidity Notification | 2 Years Battery Life
Historical Data Tracking
Data is tracked in real time. An alert notification will be sent to your phone when abnormal environment is detected.
Works with other HomeKit-enabled accessories in Apple Home app to make your life easier.
Works with Apple HomeKit
Aqara Home Automation
Automatically Adjusts Indoor Humidity Level
When Used with a Smart Plug and Humidifier
* An Aqara Smart Plug is required.
hub icon
Hub
smart plug
Wall switch
Automatically Set Indoor Temperature and Humidity to the Right Level with an Air Conditioning Controller
* Air Conditioning Controller coming soon
hub icon
Air Conditioning
Controller
Automatically adjust indoor humidity with a humidifier.
hub icon
Hub
smart plug
Wall switch
Automatically adjusts Indoor Humidity Level
Automatically adjust indoor temperature and humidity to a comfort range.
With the Door and Window Sensor, you can turn on alarm mode when you leave the house or when you are asleep. If a door or window is opened, the Hub will sound an alarm and send a notification to your phone.
hub icon
Automatically set indoor temperature
Advanced Technology
Aqara Temperature and Humidity Sensor adopts an industrial-grade sensor provided by the industry-renowned Sensirion company which has the humidity detection accuracy of ±3% and temperature detection accuracy of ±0.3℃. The production process is strictly supervised to ensure high quality.
Temperature and Humidity Sensor Advanced Technology
