Aqara Smart Plug EU
Aqara Smart Plug
Automate Traditional Electrical Appliances with Ease
Remote Control | Timed Switching | Voice Control | Electricity Statistics | Overheat & Overload Protection
* A Hub is required
Only for sale in Russia, and other regions will go on sale soon.
Aqara Smart Plug
* A Hub is required
Aqara Smart Plug can turn traditional electrical appliances into smart devices easily.Numerous smart scenes can be realized when it works with other Aqara smart devices.
Aqara Smart Plug can turn traditional electrical appliances into smart devices easily. Numerous smart scenes can be realized when it works with other Aqara smart devices.
Forgot to turn off the fan when you hurry outside? Just take out your phone and open Aqrar Home app. Then, you can turn off all the electrical appliances at your home easily.
Remote Control with Your Phone
Timed Switching Provides You with a Disciplined Life
Coffee maker turns on automatically at 7:00. With an aromatic coffee, your wonderful day is ready to start.
19:00 Humidifier automatically turns on before you arrive home to provide you with a comfortable environment.
Control Electrical Appliances with Your Voice Easily
You can use your favourite voice assistant to enjoy a smart life.
“ Siri, turn on the egg cooker. ”
“ Siri, I want some coffee. ”
*It is recommended to use iOS 12.0 or above. A HomePod, Apple TV ( tvOS 11.0 or above ) or an iPad ( iOS 12.0 or
above ) that has been set as the home center is needed to remote control HomeKit accessories.
*It is recommended to use iOS 12.0 or above. A HomePod, Apple TV ( tvOS 11.0 or above ) or an iPad ( iOS 12.0 or above ) that has been set as the home center is needed to remote control HomeKit accessories.
Connected Automation, Stable and Smart
When the network at your home is not stable or disconnected, as long as the Hub is working normally, the connected automation between Smart Plug and sensors can still work properly.
Turn Off the Fan with One Button
Lights Turn On As Soon As the Door is Opened
Lights Turn On and Off with People Come and Go
Electricity Statistics. Record Every Kilowatt – hour of Electricity
Aqara Smart Plug can monitor the actual working power precisel. Also, it can provide
electricity statistics to realize electricity visualization making sure the electricity is at your command.
* 16A electrical appliances are not supported.
Aqara Smart Plug can monitor the actual working power precisel. Also, it can provide electricity statistics to realize electricity visualization making sure the electricity is at your command.
Overheat and Overload Protection
When Smart Plug detects that the power or temperature is over the limit
threshold, it will automatically cut off the power to protect you from any danger.
When Smart Plug detects that the power or temperature is over the limit threshold, it will automatically cut off the power to protect you from any danger.
Multiple Safeguards in Place to Ensure Your Safety
Utilizing V- 0 grade flame- retardant material, the Smart Plug is safe and reliable. It is equipped with a protective
shell to prevent electric shock by accidents. It can support electrical appliances with a maximum power consumption of 2300W.
Utilizing V- 0 grade flame- retardant material, the Smart Plug is safe and reliable. It is equipped with a protective shell to prevent electric shock by accidents. It can support electrical appliances with a maximum power consumption of 2300W.
Supports More Powerful Zigbee 3.0 Protocol
Securer
Better compatibility
Integrated solution
More stable network
Low power consumption
Securer
Integrated solution
More stable network
Easy Connection in 3 Steps
Open Aqara Home App and scan the QR code in the manual or on the package box.
Long press the reset button for more than 5 secondsuntil the LED indicator flashes in blue consecutively.
The Hub will prompt a voice messagetelling you the accessory is added successfully.
Model :
SP – EUC 01
Dimensions :
Φ 62 × 77.5 mm ( Φ 2.44 × 3.05 in. )
Wireless Protocol :
Zigbee 3.0
Electrical Rating :
250 V AC, 50/60 Hz , 10 A, MAX. 2300 W
Ambient Temperature :
0 – 35°C ( 32°F – 95°F )
Operating Humidity :
0 – 95% RH, non – condensing
Model : SP – EUC 01
Wireless Protocol : Zigbee 3.0
Electrical Rating : 250 V AC, 50/60 Hz , 10 A, MAX. 2300 W
Dimensions : Φ 62 × 77.5 mm ( Φ 2.44 × 3.05 in. )
Ambient Temperature : 0 – 35°C ( 32°F – 95°F )
Operating Humidity : 0 – 95% RH, non – condensing
