LED Light Bulb (Tunable White)
Aqara LED Light Bulb
Tunable White
Create a comfortable ambience at any moment.
Adjustable Color Temperature | Automation | Voice Control | App Control
works with mijia
Match Your Mood or Activity
Customize the perfect ambience for every room, from a dim bedroom to a bright kitchen. Seven preset modes for your daily life and you can also customize your preferred scene.
Relax
Relax
Night Light
Movie
Movie
Dinner time
Dinner time
Reading
Reading
Custom
Custom
Good Morning
Aqara LED Light Bulb color temperature: 2700K-6500K
Control Lights Anywhere Anytime
You can control lights via the app when you are away from home. No need to worry about forgetting to turn off lights. Turn on the ambient light when you are heading back home. Simply tap your phone to turn off all lights at night and enjoy your sound sleep.
Control Your Lights with Your Voice, Free Your Hands
Ask your favorite voice assistant to turn on/off, adjust brightness and color temperature for you.
* Aqara Hub is required and sold seperately.
Lights Automatically Turn On When You Open the Door
When you open the door in the evening, Door and Window Sensor will be linked to control the Aqara LED bulbs. No matter how late you get home, the light automatically turns on.
Hub
Hub
LED Light Bulb
LED Light Bulb
Hub
Hub
LED Light Bulb
LED Light Bulb
Aqara LED Light Bulb Knows If You Are Here or Not
It turns on the light when you are here. It turns off the light when you walk away.
Hub
Hub
Motion Sensor
Motion Sensor
LED Light Bulb
LED Light Bulb
Hub
Hub
LED Light Bulb
LED Light Bulb
Aqara LED Light Bulb Works with More Smart Devices to Enrich Your Daily Life
For example, you can rotate the Cube Controller to adjust brightness, push it to change the color temperature, shake it to turn on or off the light.
Hub
Cube controller
Cube Controller
LED Light Bulb
LED Light Bulb
Hub
Hub
LED Light Bulb
LED Light Bulb
Schedule Setting
Set different light schedules to make your life more comfortable.
Wake-up
Wake-up icon
7:30 Wake up
( Brightness 5%, color temperature 6500k)
Get home
Get home
19:00 Wake up
( Brightness 50%, color temperature 4000k)
Reading
21:00 Reading
( Brightness 100%, color temperature 4000k)
Relax
Get home
22:00 Relax
( Brightness 75%, color temperature 2700k)
Smart Home Even If The Internet Is Disconnected
When your home network is unstable or disconnected, as long as the Hub is powered, automations associated with the Aqara LED Light Bulb still work properly.
Tunable White
Tunable White
Adjustable Brightness
High Brightness
High Brightness
Automation
High Brightness
Voice Control
Voice Control
Custom scene
Custom scene
Schedule
Schedule
E27 Holder
E27 Holder
Long lifespan
Long lifespan
Aqara Home Automation
