Door and Window Sensor P2
Aqara logo
When the iconic sensor meets Matter support.
Please note: A Matter-compatible Thread Border Router is required
Native Matter Support
Allowing the direct connection to platforms including Apple Home, Google Home, Amazon Alexa and more.
Build upon thread protocol
Build upon Thread Protocol
Providing robust, low-latency, and mesh-capable communication with the Thread protocol.
Local Home Automations
Seamless integration with smart home ecosystems of your choice without relying on cloud services.
Local and Remote Alarm
Get real-time alerts on your smartphone when the sensor is triggered, no matter where you are.
Easy and Flexible Installation
The sensor is easy to install with its strong sticker. Also, an alternative thin magnet plate is included for flexibility.
Future-Proofing via OTA
Tamper alarm, adjustable sensitivity, programmable button... More features will be available as an OTA update in the future*.
* To use the Door and Window Sensor P2 with a particular ecosystem, a Matter-compatible Thread Border Router is required
Entering the Matter Era
Matter provides a more cohesive, unified smart home experience for users. It simplifies the process of setting up and managing devices and allows seamless interoperability across smart home devices and platforms.
matter logo
RELIABILITY
SIMPLICITY
SECURITY
INTEROPERABILITY
As one of the first sensors to support Matter natively, the Door and Window Sensor P2 connects directly to Apple Home, Google Home, Amazon Alexa, Samsung SmartThings, and Aqara Home  through the Matter-compatible  Thread border router. This will build rich and varied smart home scenarios and can work entirely on your local network.
works with SmartThings
works with alexa
works with Google Home
works via Matter with Home Assitant
* The functionality such as automation conditions may vary throughout the different ecosystems.
Matter Controller and Thread Border
Router Support: what is required?
To add the P2 to a particular Matter-enabled app, your device or devices will need to have both Matter controller and Thread border router functionalities. In case you are looking for a one-step solution or intend to upgrade the existing situation, there are several options for different cases:
Minimum Requirement:
A growing number of Thread Border Routers with Matter controller functionality are tested:
Apple TV 4K (3rd gen, 128 GB)
Apple TV 4K (2nd gen)
HomePod (2nd gen)
HomePod mini
SmartThings Hub v3
Aeotec Hub v3
SmartThings Station
works with alexa
Echo (4th generation)
Nest Hub (2nd gen)
Nest Hub Max
Nest Wi-Fi Pro
Home Assistant Yellow
Matter-enabled app
alexa icon
(e.g., Alexa)
Matter-over-Thread device
(e.g., Door and Window Sensor P2)
A 2-in-1 that supports this app
(e.g., Echo (4th generation))
Optional:
Using a Matter controller and a separate Border Router
In case you already have a 2-in-1 Matter Controller & Thread Border Router, but want to connect the device to an additional app, you can just add a more common and affordable Matter Controller to your setup:
Matter-enabled app of your choice
(e.g., Apple Home)
A Non-Thread Matter Controller
Apple Home pod
(e.g., Apple HomePod (1st generation))
Achieving the best functionality and Aqara Home support:
Aqara Hub M3
Add Aqara Matter over Thread devices to Aqara Home and get additional functionalities and improvements such as longer battery life. In this case, Aqara Border Router such as Hub M3 will be required.
Aqara hub support
Why Thread Protocol?
Thread Zigbee Wi-Fi
Native IP Addressability Yes No Yes
Practical Network Size Limit 200+* 100+ ~50
Typology Mesh Mesh Star
Stability Highest
[Highest + dynamict leadership]
High Medium/Low
Security Highest
AES-128, ECC
High
AES-128
High
AES-128/256
Power Consumption Very Low Very Low High
Always-on Open/Close Detection for Your Ease of Mind
Stay informed and secure with real-time notifications on your smartphone whenever the sensor detects activity. You’ll never miss a potential security threat and keep everything under control, whether you’re at home or away.
Doors
Doors
Windows
Windows
Toilets
Toilets
Refrigerators
Refrigerators
Safety boxes
Safety Boxes
Bird cages
Bird Cages
* Please note: the functionality such as automation conditions may vary throughout the different ecosystems
Door and Window Sensor P2 on first aid cabinet
By installing the P2 on a first aid kit, medical professionals can monitor when it is opened, ensuring that it is used appropriately and restocked when necessary.
The P2 can also be placed on a safe box in a home or office to alert owners if it is opened by unauthorized personnel, preventing the loss of important documents, cash, or valuables.
Maximizing Efficiency with Voice Assistants
Using the supported voice assistants, you can receive alerts about events such as door entries, or ask about whether a door is open, keeping you on top of things at home. This keeps daily tasks running smoothly and conveniently, allowing you to make the most of your time.
Siri icon
Siri
google assistant icon
Google Assistant
alexa icon
speaker
Alexa notif
speaker
Siri notif
Installing and Using It Is a Breeze
Easy Installation
With its compact design and adhesive back, the sensor easily integrated into any interior. The upgraded stickers will not leave traces after being removed, and the additional flat magnet brings more installation flexibility.
Adhesive Back
Door and Window Sensor P2 flat magnet
Flat Magnet
Long Battery Life
Additionally, it is equipped with a powerful CR123A battery, it provides uninterrupted protection with infrequent battery changes.
* The battery life may vary depending on the Thread Border Router and the Matter-enabled app(s) the sensor is connected to. For best results, Aqara border router is advised
Comes with Additional Features in Aqara Home App*
The customizable settings through the Aqara Home app will be expanded connected with Hub M3.
OTA Aqara home
Adjustable Sensitivity
Users can fine-tune the sensitivity of the sensor within a range of 1-3 cm and adjust the sleep time based on specific scenarios.
Tamper Alarm
The Tamper Alarm feature will send immediate alerts to your smartphone if the sensor is tampered with.
Save the energy when the door or window is open
IF Door and Window Sensor is opened
THEN Turn off the thermostat to reduce energy consumption and your carbon footprint
Door and Window Sensor P2 + Border Router + Radiator Thermostat E1
No more lights suddenly turning off while you are in the toilet
IF Door and Window Sensor P2 is opened
(i.e. the toilet cover was opened, which indicates that the toilet is used)
THEN Deactivate the automation “Turn off the light if no motion was detected for 2 minutes”
Door and Window Sensor P2 + Border Router + Motion Sensor
