The mere idea of returning home to find that your valuables are no more or that your home has been ransacked is a horrifying thought. However, the fact is that burglaries and thefts are more frequent than we would like to think.
Every 13 seconds in the US a burglary occurs, and in the EU, there were 1.7 million reported burglaries in 2019. Moreover, the internet has provided a platform for a new kind of theft called “porch pirates”, who steal packets from peoples’ doorsteps.
Table of Contents
How To Secure Your Home From Burglaries And Theft
So how do you protect your home and loved ones from these types of threats? Here are 10 tips that can help you secure your homes from burglaries and theft.
1. Lock your doors and windows
It sounds like a truism, but just the simple thing of locking the doors and windows can help to discourage burglars. Even if you are just going for a quick errand, ensure that all entry points to your home are locked. If you have sliding doors, fit a metal rod in the track so that they will not be forced open. You can also add door and window sensors so you can be alerted when suspicious movements on your doorways and windows occur.
2. Install smart door locks
Smart door locks provide further security to your house. They enable you to monitor the doors and they can also alert you when someone enters or leaves your home. Getting a video doorbell adds visibility of strangers in your front door. Some also have functionalities like fingerprint scanning or entry codes which make it hard for any person unauthorized to have access.
3. Get a home security system
A home security system can be used to monitor and survey your home every day, all the time. This can be the likes of cameras, motion sensors, and alarm systems that can also be able to alert you and the authorities when something suspicious is happening.
4. Hide your valuables
Do not display your valuables on the windows and doors. This comprises costly electronics, jewelry, and money. Avoid making it easy for burglars to know the things they should carry.
5. Light your yard
A well-illuminated yard can act as a deterrent for burglars as they operate in the dark. Consider putting up motion sensor lights that will turn on when movement is detected and maybe keep some outdoor lights on at night. You can also install motion sensors on the perimeter to monitor the movement within your property.
6. Secure your garage
Your garage is another point of entry for burglars. Always keep it locked and think about purchasing a smart garage door opener that lets you monitor and control your garage from your smartphone.
7. Conceal your extra house keys
Although it is rather convenient to place a spare key under the plant or mat, these are the first places they will check. However, you can leave a second key with a trusted neighbor or purchase a smart lock so you can temporarily assign door codes for visitors or trusted individuals.
8. Pretend someone is home
If you are going out of town, just keep some lights on using smart bulbs to make it look like that the house is occupied. You can also employ smart plugs to switch on and off appliances like TVs at specific intervals to create an impression that someone is around. You can also use smart switches to program lights at home.
9. Consider getting a safe
A safe is a good investment and it provides an added security for your valuables. Search for a safe that is bolted down and resistant to physical attack as well as fire.
10. Secure your porch and mailboxes
Porch pirates mostly aim at unattended parcels and mailboxes. You should probably get a mailbox with a lock or a delivery bin that can be opened with a code or a smartphone app.
Aqara: All-Inclusive Smart Home Security System
Aqara provides a complete home security system with a range of products that are designed to work together to give your home the ultimate protection.
Aqara Camera Hub G3
The Aqara Camera Hub G3 goes beyond visuals. This 2-in-1 marvel features a 1080p camera for clear surveillance alongside a built-in Zigbee hub to connect your entire Aqara security system. Receive mobile alerts, trigger automation upon motion detection, and enjoy local or cloud storage for peace of mind. Get clear live footage directly to your phone, the perfect device for remote home surveillance.
Aqara Motion Sensor P1
The Aqara Motion Sensor P1 boasts a 170° field of view, keeping an eye on expansive areas. It can be programmed to activate it along with other smart devices like smart lights and alarms for added security. Customizable detection zones and sensitivity levels ensure you only receive relevant alerts. Plus, its long 5-year battery life and compact design make it perfect for discreet placement.
Aqara Door and Window Sensor T1
The Aqara Door and Window Sensor T1 can be installed on doors, windows, and other entry points in your home. It sends alerts to your phone whenever there are unfamiliar movements. It can assist you in monitoring who leaves and enters your house and can activate other devices associated with it.
It also provides instant notification whenever a door or window is opened or closed. Compact and easy to install, it seamlessly integrates with your Aqara system, allowing you to trigger alarms or activate smart home routines for complete control.
Aqara Vibration Sensor
The Aqara Vibration Sensor detects even the slightest tremors and tilts, keeping you alert of potential break-in attempts or security breaches. Mount it on doors, windows, drawers, or valuables for ultimate peace of mind. It also doubles as a fall detection sensor for added home safety.
Other Aqara products
In addition to the full security package, Aqara provides many other products that you can integrate into your smart home security system. Smart light bulbs and smart video doorbells can enable you to see a live view or talk to anyone ringing your doorbell.
Where To Buy A Smart Home Security System
Dependability and efficiency are critical in home security. Aqara provides high-quality smart home security products that help you prepare before it’s too late. Adopt these 10 tips to protect your home. You can get Aqara products from the Where To Buy page of our official website to know authorized retailers near you.
