Smart Home Controllers
Browse our range of smart home controllers. These devices allow you to remotely control and automate your home.
NEW
Smart Wall Switch H1 EU(With Neutral) - Grey
NEW
Smart Wall Switch H1 EU(No Neutral) - Grey
NEW
MagicPad S1 Plus (SEA&ME Version)
NEW
Smart 20A Switch H1 (SEA Version)
NEW
Smart Wall Switch Z1 Pro
Inspiration at Your Fingertips
NEW
Dual Relay Module T2
Radiator Thermostat E1
Cube-T1-Pro
Cube T1 Pro
Cube T1 Pro
Smart Pet Feeder C1
Smart Pet Feeder C1
Smart Pet Feeder C1
Magic Switch S1E
Magic Switch S1E
Wireless Mini Switch
Wireless Mini Switch T1
Smart Plug (EU Version)
Smart Plug(EU Version)
Smart Plug (US Version)
Smart Plug(US Version)
Image Smart Wall Switch H1 Neutral
Smart Wall Switch H1 EU (With Neutral)
Image Smart Wall Switch H1 No-Neutral
Smart Wall Switch H1 EU (No Neutral)
Wireless Remote Switch H1
Smart Wall Switch With Neutral
Smart Wall Switch (With Neutral)
Smart Wall Switch (No Neutral)
Smart Wall Switch H1 Triple Rocker (With Neutral)
Smart Wall Switch H1 Triple Rocker (No Neutral)
Single Switch Module T1 (With Neutral)
Single Switch Module T1 (No Neutral)
What can you do with Smart Controllers?
Smart Switches
A smart switch offers a convenient way to control your lights with a tap, smartphone app, or voice command. It allows you to schedule automated on-off times for efficiency, simulate occupancy when you’re away using vacation mode, and save on electricity bills by setting lights to turn off when rooms are unoccupied. Learn more about how smart switches work.
Smart Thermostats
A smart thermostat provides precise control over your radiator, letting you adjust temperatures via your phone. It can preventing wasteful heating of an unoccupied home by automatically switching off when you leave, or you can set the system to preheat your home before your arrival. Plus, it allows personalization of heating settings for each room, ensuring everyone enjoys their preferred temperature.
Smart Plugs
A smart plug can transform any electronic device into a smart one, offering a myriad of functions. It allows remote control of devices, enabling you to switch them on or off via phone or voice command. You can automate daily routines, such as starting your coffee machine before you wake up or shutting down your computer each evening. Additionally, it monitors your devices’ energy consumption, providing insights to help you save energy.
Smart Pet Feeders
A smart pet feeder ensures your furry friend is well-cared for, offering several beneficial features. It helps maintain a consistent feeding schedule, aiding in managing behavioral and health issues by feeding your pet at regular times daily. It carefully controls portions, assisting in keeping your pet healthy.
FAQs About Aqara Smart Controllers
Some Aqara smart switches let you connect them directly to your Wi-Fi. Others will need to be synced to a control hub.
Smart switches work with a variety of LED, CFL, and incandescent light bulbs. Check with your bulb's manufacturer to see if they're compatible.
If you're comfortable handling electrical wiring, you can do this project yourself. However, those without the right training should hire a professional instead.
The ability to automate your heat and turn off the radiator when you don't use it helps you save a lot of money.
Aqara smart radiator thermostats are fairly straightforward to install if you follow the instructions that come with them. However, some homeowners prefer to hire a professional.
Majority of radiator heaters are compatible with smart thermostats. Check the manufacturer's manual and product specifications for your radiator to see if it works with a smart thermostat.
Smart plugs can control any electrical device that turns on and off. This includes coffee makers, fans, lamps, and televisions.
Smart plugs use a minimal amount of electricity to stay connected to your network, but their power usage is extremely small.
Typical smart plugs aren't designed to deal with outdoor weather. Only use a smart plug outside if it's rated for outdoor usage.
This depends on the feeder you pick. Some will dispense meals for specific pets with specific chips on their collars.
Smart pet feeders typically have a backup battery, so your pet still gets fed if the power goes out.
Aqara's feeders only work with dry food. Most models don't use wet food because automated feeders can't handle it reliably.
