LED Light Bulb (Tunable White)
What functions does the Aqara LED Light Bulb have?
The Aqara LED Light Bulb supports adjustable brightness, color temperature, app control, automation connection with other devices, timer switch, delay switch, and other functions.
Does the Aqara LED Light Bulb support adjustable color?
No, the Aqara LED Light Bulb only supports adjustable brightness and color temperature.
Can the Aqara LED Light Bulb be directly controlled by a mobile phone?
No, the Aqara LED Light Bulb must first be bound to the Aqara Hub and then it can be controlled through the mobile app.
What is the input voltage range for the Aqara LED Light Bulb?
The Aqara LED Light Bulb supports 220-240V~ 50/60Hz input voltage.
Can the Aqara LED Light Bulb be used independently?
The Aqara LED Light Bulb can be used as an ordinary light bulb independently. However, if you want to use app control, smart connection or other functions, the bulb must be first bound to an Aqara Hub.
What  standard does  the Aqara LED Light Bulb use?
The Aqara LED Light Bulb uses standard E27.
Does the Aqara LED Light Bulb support a lamp with a knob dimmer switch (for example, table lamps with knob dimmer switch)?
No, do not install the Aqara LED Light Bulb in a lamp with a knob dimmer switch to avoid damage.
How do I reset the Aqara LED Light Bulb?
Turn the light bulb on/off 5 times continuously with the physical switch. The bulb is reset successfully when the bulb flashes twice quickly and then stays on.
Does the Aqara LED Light Bulb support voice control?
Yes, the Aqara LED Light Bulb supports Siri, Alexa and Google Home voice control (the bulb must be bound to an Aqara Hub to activate voice control function).
