1. You can quickly press the button on the top of the camera three times to initiate ZigBee end device connection. G2H Pro support ZigBee 3.0 protocol and can connect 128 end devices at most.
2. You can scan the QR code generated by Aqara Home app to connect to internet. After the camera is powered on, please open the app and connect the device to 4GHz Wi-Fi, according to the voice prompt. Then, the QR code is generated, and you can scan the QR code through the G2H Pro lens for the network connection.
3. It supports 2.4GHz IEEE902.11b/g/n Wi-Fi protocol. And it doesn’t support 5GHz Wi-Fi. When connecting the mixing frequency router, it is recommended to separate 2.4GHz and 5GHz Wi-Fi to avoid abnormal connection.
4. Please check the distance between camera and router, and make sure the Wi-Fi signal is strong enough. If Wi-Fi connecting abnormally, please use Wi-Fi signal amplifier or mobile router to ensure that the device can receive Wi-Fi signals well. Please make sure connecting to 2.4GHz Wi-Fi. Please check if the Wi-Fi SSID or Wi-Fi PWD is correct.
5. It will take at least 18GB to store one day’s video. Generally, the TF card with 512GB capacity is expected to be stored for 4 weeks, totaling 28 days.
6. Yes. However, you can’t view the video through Aqara Home app because of no internet.
7. It supports the TF card with CLASS 4 above and format of FAT32. The capacity is 512GB at most. However, We suggest you use the TF card with CLASS 10 above.
8. At most 4 .
9. It supports magnetic suction and flat installation. You can use 3M glue in the accessories to paste the iron sheet on the non-magnetic material surface, or use fastening screws to fix the iron sheet on the non-magnetic material surface, and then fix the camera.
10. At most 5, maximum 5MB per ringtone.
At most 4 .
Camera Hub G2H Pro
Camera Hub G3
Camera Hub G2H
Smart Video Doorbell G4
Get the latest news from us.
Camera Hub G3
Camera G2H Pro
Click any Menu
