Aqara Door and Window Sensor
Detects if a window or door is open in real time.
Peel & Stick | Triggers Aqara Hub Alarm and Push Notification | 2 Years Battery Life
A Smart Sensor for Every Door and Window
Aqara Vibration Sensor can be placed anywhere according to your needs, guarding your home.
Works with other HomeKit-enabled accessories in Apple Home to make your life easier.
Works with Apple HomeKit
Aqara Home Automation
Turn On the Lights Automatically
When You Open the Door at Night
When you open the door in the evening, the Aqara Door and Window Sensor will send a signal to the Aqara Wall Switch to turn on the lights. No matter how late you get home, the lights will automatically turn on.
hub icon
Hub
door and window sensor
Wireless Remote Switch
Wall switch
Security Notification
With the Door and Window Sensor, you can turn on alarm mode when you leave the house or when you are asleep. If a door or window is opened, the Hub will sound an alarm and send a notification to your phone.
hub icon
Hub
Lights automatically turn on when you open the door.
hub icon
Hub
Wall Switch
Security reminder, guarding your home.
hub icon
Hub
Advanced Technology
Aqara Door and Window Sensor detects the current status of doors or windows via the distance of the magnets inside the sensors between the sensor and the magnet. The sensor is also energy efficient and one battery can last over 2 years under normal usage.
Aqara Door and Window Sensor Advanced Technology
